Results 1 to 2 of 2
    923
    Default UMP National points chase at La Salle
    Unzicker won, (Mike Provenzano second) Jon Henry finished third. Schlenk pulled in the infield early while running 5th or so.
    Opie appeared to be on his way past Unzicker on the high side at one point, but got impatient and hit the wall in 3&4. Wasn't the same after that. Looked to have part of his right rear quarter panel rubbing into his tire. Pretty wild race. Unzicker was getting sideways around the bottom.
    Front running Sievert had yet another flat early.
    Just giving an early update. K9 was there, so I'm sure Betty will be along with a more entertaining full run down tomorrow.
    750
    Yeahhhh!!!!!! Go Unzicker. Extend that point lead!!!!!
