411 and Tazewell October 7 and 8
Rules and Purse for October 7 and 8 at 411 and Tazewell
Tazewell's portion of this weekend will be named The Chris Collinsworth Memeorial
Rules for 411 and Taz $2000 to win each night
3000 lbs anytime
open motor, no aluminun heads or block, no dry sump
must be street type cars, no clip cars, alum bodies ok must be "stock appearing" Track approvel. Call before you Haul.---no wedge bodies Rear must be enclosed.
10 inch wheels max any tire
racing springs and shocks allowed, can be relocated coilovers allowed, stock type rear suspension, 3 or 4 link, can have heim and tube trailing arms, leaf spring cars can have sliders
no quick change rear ends, 9 inch floaters ok
bert and brinn type transmissions allowed
gas only
6 inch spoiler max. Late Model type side braces allowed.
411motorspeedway.net
tazewellspeedway.net
1st Annual Fall Rumble Modified Street Purse
Night 1 @ 411
$50 Entry Fee Must be Paid before Oct 1 at the Track or Mailed to : P.O. Box 464 , Gatlinburg ,Tn 37738
$75 Entry Fee after Oct 1
Night 2 @ Tazewell
$50 Entry Fee Must be Paid before Oct 1 at the Track or Mailed to : P.O. Box 5550 , Knoxville , Tn 37928
1 2000
2 800
3 500
4 400
5 350
6 300
7 275
8 250
9 200
10 150
11-20 125
1st Annual Fall Rumble Steel Head Rules
STEEL HEAD LATE MODEL FALL RUMBLE RULES
Tazewell Engine Rule ( Engine B) Only Change Base Weight 2200#
Crate Engine : 604 12 inch Spoiler , No Weight Rule
: 602 12 inch Spoiler , 12x32 Left Side Board : No Weight Rule
Crate Engines must be sealed : GM : Nesmith : Fastrak : any other Seals Call before you Haul
411 Late Model Engine Rule : Only Change Base Weight 2300#
NO BIG BORE SHORT STROKE MOTORS
OPEN TIRE RULE
Night 1 @ 411
Night 2 @ Tazewell
PURSE
1 2000
2 900
3 700
4 500
5 400
6 350
7 300
8 275
9 225
10 200
11-20 175
These Rules and Purse will apply for Both Nights : Oct 7th @ 411 and Oct 8th Tazewell
typically what gear ratio do the mod street guys use at these two tracks?
Bartley Grant
#1 red,white and blue sportsman and mod-#24 lightning/smokehouse grill mod
www.bartleygrant.com
there telling me you can run the same gear as clarksville bartley. 650- to - 683 range.you gonna try and go??? i think the hughes gang is heading that way,and if my motor gets done,were prolly going friday.
planning on it mike,ill be driving the dan ramey owned #4. depending on his work schedule,for sure saturday at the taz and slight possibility of making down friday to 411.
Bartley Grant
congrats greg estes on your win at tazewell and a strong run at 411. pretty good racing both nights. hopefully get to race it out with some of you guys at clarksville.
Bartley Grant
