Results 1 to 19 of 19
Thread: Oil Filter ??
    Aug 2011
    20
    Default Oil Filter ??
    What type of oil filter should i use for my 2300 cc mini stock mustang?
    Feb 2010
    25
    we use a motorcraft FL 1A
    Illinois
    1,690
    NAPA gold 1515.
    Apr 2009
    Gloucester, VA
    174
    Default oil filter
    I use Wix. tried Fram and noticed a drop in oil pressure.
    Feb 2009
    Inyourmom
    230
    wix 51515r
    1,008
    i use Motorcraft FL1-HP or NAPA Gold(WIX). i also use them on my toyota 20r/22r combo.
    olin
    Aug 2011
    20
    Thank you all for the advice.
    One more question what is a good transmisson for a mini stock mustang.
    Post Falls,ID
    1,579
    51515r
    or
    185515
    www.raceidaho.com
    New England
    1,338
    Depends on what you need for a final drive will make the choice for the transmission and rear end gears. How big of a track and how much RPM you want to turn the motor are what is needed to determine that. There is no best transmission just the best one for what you need.
  10. #10
    Aug 2011
    20
    Default oil filter
    Thank you i will check in on that.
  11. #11
    had brand new mc FL 1A blow apart at the seam sunday!!! anybody had this happen before??
  12. #12
    1,008
    that's why i said to use an FL1-HP. it can hold up to high pressure. what is your pressure?
    olin
  13. #13
    Aug 2011
    20
    What Brand of oil should i run?
  14. #14
    Illinois
    1,690
    Quote Originally Posted by dwracing View Post
    I run regular 10W40 pennzoil, 5 qt. jug @ walmart usually about $13. Quaker State is good too, I get that @ menards when its on sale for $1.99/qt. Add a bottle of STP oil treatment, change every 4-5 nites. Been doing this for 5 yrs & never had any problems.
  15. #15
    Feb 2009
    Inyourmom
    230
    for a ford 2.3 are you kidding me you use 10W40....and you don't float your valves....wow are you racing in the winter
    Rotella 15w40 if your running on a 3/8
    Valvoline 20w50 that has zinc added into it...for those really hot days, bigger track or a lot of laps
    I don't care what people say any additives will change the viscosity of the oil to who knows what
  16. #16
    Illinois
    1,690
    Quote Originally Posted by Tenacious55 View Post
    Yep, conventional 10W40...in a 2.3L...in the summer...small hyd. cam, only goes to 6800 RPMs and Im just about there at the end of the straights on 1/4 mile medium banked dirt track.
  17. #17
    Post Falls,ID
    1,579
    i run Schaeffers Supreme 7000 20w50 full synthetic
    www.raceidaho.com
  18. #18
    Feb 2008
    20
    Always used castrol gtx 20/50 never had a problem. This season switched to brad penn 20/50 and I was having problems with either the lifters pumping up or floating the valves. Is this because of the oil?
  19. #19
    Aug 2011
    20
    Thank You for all the help.
