2010 Mars by BMS Modified
The car has 27 nites on it nothing but the best on it, outpace uppers with molly tubes, afco lower a's, close racing front end, pinto spindles, steel brake lines, afco radiator, all afco springs, bsb roller gas pedal, wilwood pedals and brake pads all the way around, ultra shield full containment seat, simpson camlock belts, rebco gauges op,fp,temp and recall tach, quick disconnect power, window net, tear drop cell rci, car has quick change in it with bsb birdcages and floater, and will come with a 9" too, bsb pull bar, afco shocks, tires an wheels, killer roller, No Motor or Transmission unless u want it that way. Im sure i have forgot something but you can see its all there. Im not putting new body on it for this price sooo. $7000
email: rah97@cableone.net
phone: 620-342-5172
I have a nice 393, its a 509 block splayed, cola crank, eagle rods, weisco pistons, dart heads, all good stuff nice motor makes good power, motor built by millert. $4000
I have a nice 377 its a 509 block splayed with callies crank, lunati rods, je pistons, dart heads, no cam, motor built by millert has 2 nites on it since new. $5000
