Winterizing your race car
I originally had this as storing tires question only. But decided to change it to winterizing your racing operation.
As the off season approaches, I have some questions about storing tires. I have some new tires I bought for a track that I no longer run weekly (SD-48's), and the track I run now has an open tire rule. I would like to keep the 48's because I do intend to run that other track once or twice a year at least. I have an unheated garage and it does get cold enough a few nights a year to freeze. What can I do to store these tires over the winter months and the beginning of next season? Can I spray them down with WD-40 and wrap them in plastic? Putting them in a closet in the house won't settle good with my crew chief (wife).
What other things do you do to store your car for the winter?
Drain all the fuel out of the cell, lines, filter and carb.
Loosen rockers (if you don't plan on tearing the motor down)
Drain the cooling system to include the little plugs on the block.
Crew Chief "Tip of the day":
