Metric question
Does wheel base have anything to do with weather you have a metric chassis or not
A metric will be 108" WB. But guys modify chassis all the time. I used to run 74-77 monte carlo frames cut down from 115" to 108". Ive also seen some shorten metrics down to 104". What do you (think) you have?
I have a 77 regal it's set up like a mid 80s Monte so that makes it metric right wheel base is 115
With a 115" wheelbase, as Dirtman pointed out, you likely DO NOT have a metric. I suppose one may have lengthened the wheelbase, but why? This larger frame/wheelbase is often referred to as the "Chevelle."
"big gm" is most likely an A body, which covered pretty much every gm car all thru the 70s
metric cars are 1978-1988 monte, malibu, elcamino, grand prix, regal, cutlass, boneville, caballero, lemans and thats just off the top of my head, there were a few canadian metric "g-body" cars as well, i also think there was a caddy model, but if its older than 78 its not a metric
115?
112 2 door chevelle, cutlass etc.
116 4 door chevelle, cutlass etc.
116 monte carlo 73-77
Thats not a metric, its an "A" body GM chassis. Nothing will "make" it a metric.
its a A body frame,..lot better than a metric when set up right!! an take less $$$ to set it up than a metric,..plenty of parts availability too!! id cut it down to as short as wheel base rules allow!!
