I run 53% rear as well, but we don't have much HP. Probably somewhere in the 450 range. And we do just fine with 53%. But I can imagine with a stronger motor, you will need more rear %. Try scaling the car with the amount of fuel it will have at the end of the feature. And put your rear % at 55.
Crew Chief "Tip of the day":
