08 rocket blue grey frontend with wide rf
2008 Blue/Grey Front (Wide or Narrow) Rocket BY TIM LOGAN RACING
• New Winters lightweight rear end (4.86)
• New Rocket bearing bird cages
• Greasable Out-Pace Rods and Lowers
• ALL TEFLON HEIMS
• NEW MSD SYSTEM
• Woodward Collapsible steering shaft
• SWEET rack and servo
• ATL fuel cell
• Quick-Car gauges and Ignition panel
• LIGHT WEIGHT BATTERY
• Quick-Car dual ignition wiring harness
• All white body (good enough shape to start season with)
• Wilwood lightweight hubs
• US BRAKE calipers and master cylinders
• PRC radiator
• Rocket Ford/Chevy combo motorplate
• Trick fiberglass roof (black)
• New RJS seatbelts
• Aeroquip fuel lines and fittings, fuel filter included
• Wilwood brake and clutch pedals
• BSB aluminum J-bar
• TWM cam-motion J-bar frame moung
• TWM adjustable pinion mount
• TWM 6th coil assembly
• US Brake rotors
• Coleman adjustable throttle pedal
• Port City uppers and spindles
• Car has around 25 races on it, excellent condition, black powder coat still shiny and nice, nothing on car not in perfect condition, never bent or clipped
• ASKING $15,500 CALL 304-694-2277 OR EMAIL FOR PICTURES
• OPTION 2 WILL SELL JUST THE CHASSIS WITH COMPLETE BODY, GUAGES, TEL TACH, AND all new FRONT SUSPENSION AND BRAKE LINES FOR $ 8,000
2004 24 FOOT ENCLOSED TRAILOR, HAS RAMP OVERS AND A NEW WINCH $3500 OBO
STEEL BLOCK 430, 1 SEASON ON DART BLOCK,DART IRON EAGLE PLATNIUM 230CC HEADS, BORDIX HV1 INTAKE, HARTLAND SHARP ROCKERS, NEW ISKY VLAVE SPRINGS, SET UP FOR WET OR DRY SUMP, NEEDS ROTATING ASSEMBLY, $3500 OBO
Rocket
does the trailer have swing doors or ramp ? thank you
