4 cyclinder Dirt track Neon race car
4 Banger #95 NEON for sale
1999 Dodge NEON Sport Coupe
2.0 DOHC .030 over, all ARP fasteners ,Cometic gaskets, total seal rings, gates timing belt, mechanical tensioner, run on Mobil 1 15w-50 full Synthetic Extended Pref.oil and VP 110 race fuel
All machine work done by Canton Automotive Machine
PT. Cruisier valve train parts 2.7 rockers ect , all new from dodge dealer when put together. Crane 16 cams
Crowl springs and retainers.
Head is shaved, ported and polished. Stock polished and ported aluminum intake with neck bored to fit modern preformance 60mm throtle body with manual IAC feed with a COLD AIR 3.0 caravan intake tube with high flow washable K & N washable air filter .
Stock Cluster and Auto Guage /AMP/Oil Pressure/Water temp.
Mishimoto aluminum racing radiator
MSD coil /Granatelli wires/ Ngk plugs
AFX racing EC U
TTI long primary tube stainless steel header wrapped with heat wrap from the head to the flang exiting into 3inch exhaust back to drive side wheel.
3.55 gear transmission with lock dif ( tig welded gear and pin) delrin bushings in shift linkage cables.
Grip force stage 3 racing clutch with red line oil in case.
NAPA CV 1/2 shafts.
Solid motor mounts and adjustable bobble strut .
ACR front spindels and hubs, 2nd GEN (2002 ) front brake rotors with Hawk HP racing brake pads.
Delrin bushings in rear suspension.
New brake lines steel and rubber.
Very safe cage 1 3/4'' .110 wall thickness steel, 2 door bars in the pass. side / 4 door bars in driver side with gusset down tubes and 1/8'' plate welded in between each from top to bottom,Back drop bars welded to 3/16''plate on top of strut body stamping (welded to cage bar not body) making it a soild mount for the strut .front strut cross bar . Window net/Kirkey 17" seat with shoulder containment and cover ,Simpson 5 point Harness .
2 races on right side touring type struts, ball jionts.
Tons of parts ,10 8x15 Racing tires, Goodyears ,American Racer, 4 Basset 8x15 Racing Bead loc rims 3" offset, 3 Basset non bead loc rims , 6 wheel Adpters ECT.
Set up info book ,tire psi, offsets, cambers ect.
This is the 2010 250 Speedway track Champion winning 8 features and 15 heats. This Car also finshed 3rd at the MCS 1000.00$ to win race(1st trip there for both on us )and won the heat , Started on the POLE,finshed 3rd at the 1st Hilltop Speedway Outlaw mini stock Nationals.This car is fast and dependable Only 1 finish out of TOP 5 all year and NEVER had a DNF . Car didnt race in 2011.Car is RACE READY . I have RECEIPTS for all the good stuff . Im a Machinist and very meticulous about my work!This is the 15th Dirt Car I have built. Sure I left out somethings. $3500.00
http://www.youtube.com/user/scottbush95
lol why does everyone run monster truck tires on the front on that tiny track..
LOLO there not Truck tires there RACE TIRES 8"x15" at 82 " circumf. WHY WOULD anybody run d.o.t. tires on a RACE CAR or that 1500$ demo car . look carfuly before puting foot in MOUTH JR go back to sleep in front of that flat screen. 3 championships most do something Right.
