Intercomp setup tools wireless scales and more
SW777 RFX wireless scale system Part #170127 & 170133
Intercomp scale pad leveler with roll-off pad part#170133
scale pad case and custom built scale cart,these have only been used 12 times and do not even have the protective covering removed yet,sold our car and no longer need all pieces listed above sold as a package.
Price is $2500 call with any questions
Greg Bates
217-714-1711 cell
217-253-2721 shop
•Fully Integrated RFX™ Wireless Technology
•Encryption Ensures Secure Wireless Communication
•USB & RS232 Output
•Certified to 0.1% Accuracy
•1,500 lb (700 kg) Pad Capacity
•6,000 lb (2,800 kg) System Capacity
•Weights Displayed on RFX™ Wireless Indicator & in RaceWeigh™ Software Simultaneously
•Stores 100 Chassis Setups
•Baseline Setup Recall
•Center of Gravity Calculation
•User Selectable Display Modes
•Target Tune Feature
•Giant 0.5" Display Characters
•Backlit Display
•View ANY Combination of Scale Pad Weight & Percentage
•400hr Average Battery Life in Pads
•15" x 15" x 2.5" (381 x 381 x 64mm) Wireless RFX™ Billet Pads
•One-Touch Wireless Indicator with Rechargeable Batteries, Battery Charger & Case
•Race Car Management Software
•RaceWeigh™ Software & Wireless Node
•Pad Storage Case
•USB Cable for PC (PC not included)
•AA Alkaline Batteries for Scale Pads
•Designed to Fit Any 15" (381mm) Scale Pad with 2.5" (64mm) Pad Thickness
•Enables Car to be Rolled On & Off the Scale Pad with Little Effort
•Aluminum Construction
Intercomp Laser scale leveling system used once like new
Part#102018 Price is $225
•Level Pads, Roll-Offs or Setup Racks
•Laser Sighting with a Virtually Unlimited Range
•Compatible with All Scale Systems
•Includes Case
Intercomp Tire pyrometer/Brake temp pyro NEW NEVER USED part#102034 Price is $375
•Displays All Four Tire Averages
•Displays Tire Temperatures Simultaneously
•Stores 10 Sets of Tire &/or Brake Temperatures
•Displays 14 Tire Temperatures
•Displays 4 Brake Temperatures & Calculates Front/Rear Bias
•Measures Tire & Brake Temperature in any Sequence
•Enter Tire Temperatures Automatically via the Tire Probe or Manually via the Keypad
•Backlit Display
•Standard RS232 Output to Computer or Printer
•Selectable in Fahrenheit or Celsius
•Standard 9-Volt Battery Operation
•Includes Type K Tire Tire Probe & Case
Includes:
•Pyrometer/Timing Unit
•Type K Mini Tire Probe
•Carrying Case
Intercomp Tire Durometer/ Tread depth gauge combo with cases both are NEW NEVER USED
part#360110 Price is $75
Tire Durometer: The surface of a tire becomes harder with every heat cycle, and even new tires of the same compound can vary a great deal in hardness. If a tire is too soft for the track, it will overheat and may not last the entire race. If it is too hard, it will not get up to the optimum temperature and traction will have to be sacrificed. Intercomp's Tire Durometer enables you to make the correct tire selections for any track.
•Type-A Removeable Tip
•Reads from 0-100
•Adjustable face
•Zero button
•ASTM Certified Tire Tread Depth Gauge
•Measures tire wear in 1mm & 1/32" increments
•Aluminum construction
Tire Tread Depth Gauge: Measures tire wear in 1mm and 1/32" increments. Aluminum Construction.
Includes cases for both gauges.
any questions please call one of the phone numbres above
THANKS
SEE ALL PHOTOS @ RACING JUNK AD#2395068
