Let me say first off new to mods???? I Put a bsb slider on lr it has the 2 inch longer shaft..Because i was told everyone uses it on lr.....( spring behind) Now with car at ride highth i only have an 1 3/4 inches of compression left before it bottoms out.......
Now i kno its on compression and car is mostly up on bars and will be traveling the opposite way. But when letting up entering corners wouldn't the slider come down an compress.
How much travel do you need in compression????
Just trying not to break parts....Should i have purchased the normal shaft slider or could i change the shaft back to a normal length
