camaro wide 5 spindal ??? please help
i have a 2006 grt dlm i just clipped with a camaro clip will the grt spindals work?
did you leave the upper a-arm mounts from grt on the frame or are you going with the stock camaro mounts. if you left the grt mounts you'll be able to use the grt spindles with a little adjusting but if using the camaro mounts they will be to tall and it will take a lot of fab work to get everything to come out.
racin6mod
i still have the grt uprights but the camaro snout we can run tub uppers so all the factory stuff is gone
