Results 1 to 5 of 5
    Mar 2011
    15
    Thumbs up Huge Parts Inventory, Must See!
    PARTS
    *UPPER CONTROL ARM: W/OUT BALL JOINT (NEW) 10" 15 1000 2 60.00ea. 120.00both
    *UPPER CONTROL ARM: W/OUT BALL JOINT (USED) 10" 15 1000 1 33.00ea
    *DYNALITE WILWOOD CALIPER (USED)PN 120-4998 50.00ea
    *OLD STYLE GRT BIRD CAGE WITH NYLON SLEVE (USED)W/ SHOCK BEHIND AND STANDARD -1 85.00
    *OLD STYLE GRT BIRD CAGE BRACKET RIGHT REAR (USED) 1 45.00
    *GRT LEFT REAR CLAMP BRACKET (USED) 1 30.00 30.00
    *GRT 7TH COIL BRACKET (USED) - 1 35.00 35.00
    *90-10 BRACKET GRT (USED) - 1 50.00 50.00
    *AFCO M2 ADJUSTABLE SHOCKS SET (USED)
    (2) 3270 (1) 3290RR (1)3290LR 1 1,000.00
    *HOWE BALL JOINTS (NEW) 22300 2 71.99ea 143.98
    *HOOD PINS BLK SET (NEW) - 3 8.00ea 24.00
    *HOOD PINS PURPLE SET (NEW) 1 8.00 8.00
    *SPARK PLUG WIRES (SET) MOROSA ULTRA 40S 1 95.00 95.00
    *MSD CAP (NEW) FORD HEI 8408 2 26.00ea 52.00
    *MSD FIXED ROTOR (NEW) 8423 2 19.00ea 38.00
    *WIDE 5 HUB METAL GASKETS 3 5.00ea 15.00
    *QUICKCHANGE METAL GASKETS 2 7.00ea 14.00
    *QUICKCHANGE FELT GASKETS 2 5.00ea 10.00
    *TRANS REAR SEALS (NEW) CR19277 1 2.00 2.00
    *K&N AIR FILTER (NEW) E-3732 - 4 1/2" 1 45.00
    *FRAM FILTER (NEW) HP6A1 1 4.00 4.00
    *CARB GASKET (1 HOLE) 50054 3 5.00ea 15.00
    *CARB GASKET (4 HOLE) - 2 7.00ea 14.00
    *1" ALUMINUM CARB SPACER (4 HOLE) 1 20.00 20.00
    *LONGACRE MAG SWITCH 3 TERMINAL ON/OFF (NEW) LON4543 6.00
    *LONGARCRE START BUTTON (NEW) 4546 1 8.00 8.00
    *OUTERWEAR PRE-FILTER (NEW)10-1004-03 1 15.00
    *BSB PINON MOUNT (8 HOLE, COLOR PURPLE) 1 30.00 30.00
    *MSD BLASTER (USED)PN 8222 1 20.00 20.00
    *ALUM COLEMAN DRIVE SHAFT (38 1/2" W, LONG YOKE)(NEW) 1 225.00
    *95 SPINDLES FOR GRT (1 SET) (USED) - 1 100.00 100.00
    *AFCO 2" WHEEL SPACER (USED) 48928 1 40.00 40.00
    *6 BLADE QUICK CUT TIRE SIPER (NEW) 1 65.00 65.00
    *14" ALUM SWEDGE TUBE W/NEW HEIM 4ea 22.00 88.00
    *13" ALUM SWEDGE TUBE W/ USED HEIM 2ea 12.00 24.00
    *12" ALUM SWEDGE TUBE W/ NEW HEIM 3ea 22.00 66.00
    *STARTER CELANOID (NEW) 1 12.00 12.00
    *PENSKE SHOCK NITROGEN GAUGE(NEW RED) 1 40.00 40.00
    *QUARTER MASTER QUICK CHANGE GEARS -5.11 1 35.00 35.00
    *QUARTER MASTER QUICK CHANGE GEARS - 6.21 1 35.00 35.00
    *QUARTER MASTER QUICK CHANGE GEARS - 6.40 1 35.00 35.00
    *QUARTER MASTER QUICK CHANGE GEARS - 6.56 1 35.00 35.00
    *QUARTER MASTER QUICK CHANGE GEARS - 6.62 1 35.00 35.00
    *QUARTER MASTER QUICK CHANGE GEARS - 6.78 1 35.00 35.00
    *TD PERFORMANCE PRODUCTS ALUM PULLEY FITS SB CHEVY (NEW) 9481 - DOUBLE LOWER 1 40.00 40.00
    *TD PERFORMANCE PRODUCTS ALUM PULLEY FITS SB CHEVY (NEW) 9479 - DOUBLE UPPER 1 40.00 40.00
    *WILLY'S CARB W/ 2" 1-HOLE TO 4-HOLE CARB SPACER (USED) 750 CFM 1 500.00 500.00
    *GRT 2X2 PANARD FRAME MOUNT 2-HOLE (USED) 1 40.00 40.00
    *GRT LOWER CONTROL ARM (NEW) 17 5/8" PRESS IN (NEW) 100 21127P-2 1 65.00 65.00
    *GRT LOWER CONTROL ARM (NEW) 17 5/8 PRESS IN (USED W/ HOWE LOW FRICTION BALL JOINT) - 1 75.00 75.00
    *GRT LOWER CONTROL ARM (NEW) 16 5/8" PRESS IN (USED W/ HOWE LOW FRICTION BALL JOINT) - 1 75.00 75.00
    *GRT LOWER CONTROL ARM 16 5/8" PRESS IN (USED) - 1 35.00 35.00
    *HOLLY JET KIT #64-#99 (USED) - 1 20.00
    *WILLY'S FLOAT ADJUSTER (USED) A4 1 20.00 20.00
    *WILLY'S METERING BLOCK ADJUSTER (USED) - 1 15.00 15.00
    *ASSORTMENT OF GOLD TIE RODS W/HEIMS (USED) 5ea 10.00 50.00
    *10 1/2" GRAY RAYBURN LEFT FRONT UPPER (USED) 1 25.00 25.00
    *9" RAYBURN RIGHT FRONT UPPER (USED) - 1 25.00 25.00
    *RAYBURN BIRD CAGES SET (USED) - 1 45.00 45.00
    *GRT LIFT BAR W/ REAR END BRACKETS,HEIMS & FRAME STABILIZER (USED) - 1-75.00
    *18" SWEDGE TUBES W/ NEW HEIMS & HOCKEY STICK ENDS FOR GRT (NEW) - 2ea 25.00 50.00
    *18" SWEDGE TUBES W/ NEW HEIMS & HOCKEY STICK ENDS FOR GRT (USED) - 2ea 12.50 25.00
    *DAVIS TECHNOLOGY TRACTION CONTROL (USED) 9000 SL 1 2,800.00
    *RUFF TIRE GROOVER (GENTLY USED) RILLFIT4 1 225.00 225.00
    *LONG ACRE TIRE PRESSURE GAUGE 0-30 PSI (USED) 1 15.00 15.00
    *WINTER'S PERFORMANCE PRODUCTS MAG CENTER SECTION (USED) C 44233 1 200.00 200.00
    *WILWOOD 8 BOLT DRIVE FLANGE SET (USED) - 1 10.00 10.00
    *RED LATE MODEL CAR COVER (USED) - 1 65.00 65.00
    *RAYBURN PANARD BAR (USED) - 1 45.00 45.00
    *COLEMAN UPPER PULLEY (USED) DS 365 1 25.00 25.00
    *COLEMAN LOWER PULLEY (USED) DS 364 1 25.00 25.00
    *COLEMAN 3" FAN SPACER (USED) C345 3 1 17.00 17.00
    *COLEMAN 3 1/2" FAN SPACER (USED)C345 35 1 17.00 17.00
    *COLEMAN 4" FAN SPACER (USED) C345 4 1 17.00 17.00
    *ASSORTMENT OF CHROME VALVE STEMS - 13 1.20 15.60
    *BLUE HUB SEALS (NEW) 3ea 4.99 14.97
    *WIDE 5 INNER BEARINGS (NEW) 919-B790 3ea 10.99 32.97
    *WIDE 5 OUTER BEARINGS (NEW) 919-B690 4ea 10.99 43.96
    *WIDE 5 HUB NUTS KIT (NEW) 2ea 8.99 17.98
    *HUB KEYS AND SHIMS (USED) 1 10.00 10.00
    *WIDE 5 HUB WRENCH (NEW) 1 17.99 17.99
    *REAR END YOKE (USED) 1 10.00 20.00
    *THROTTLE RETURN BRACKET (NEW) 1 4.50 4.50
    *ASSORTMENT OF PILLS FOR FUEL PUMP (NEW) 1 10.00 10.00
    *2" SQUARE BLACK ALUM WEIGHT CLAMPS (USED) 2ea 4.00 8.00
    *2" ROUND BLACK ALUM WEIGHT CLAMPS (USED) 2ea 4.00 8.00
    *1 1/2" ROUND BLACK ALUM WEIGHT CLAMP (USED) 1 4.00 4.00
    *1 1/4" ROUND ALUM WEIGHT CLAMP (USED) 1 4.00 4.00
    *ARGO MANUFACTURE TIRE BAR (USED) 1 25.00 25.00
    *ASSORTED AIROQUIP FITTINGS (USED) 8ea 7.00 56.00
    *13" STEEL SWEDGE TUBE W/ STEEL HEIM 1 15.00 15.00
    *LONGACRE SCALES WITH CART (USED) 1 550.00 550.00
    *LONGACRE CASTER CAMBER GAUGE (USED) 1 60.00 60.00
    *WILWOOD BREAK FLUID (12 OZ) 11 5.95 65.45
    *KSE POWER STEARING FLUID 1 15.00 15.00
    *RED LINE 7590 GEAR LUBE (1 GALLON ) 1 40.00 40.00
    *K&N FILTER OIL (12 OZ) 1 5.00 5.00
    *MOBILE ONE 20W50 MOTOR OIL (QUART) 14ea 5.00 70.00
    *12" & 14" AFCO SPRINGS (USED) 8ea 25.00 200.00
    *MOROSO VALVE COVER BREATHER (USED) 1 5.00 5.00
    Can email pictures of anything.
    Accept cash or credit cards
    Thanks for looking
    interested in penske shock nitrogen guage email pic to racing17g@aol.com thanks Doug Glessner
    Default Parts purchases
    I am interested in some of your parts for sale. Please give me a call when you can to discuss this. My phone number is 402-730-0199. Thanks, Michael.
    Apr 2011
    19
    did u sell the shock guage ?if not call or txt me at 218 324 1137
    Oct 2008
    201
    Are the quick change gears for a 4.11 or 4.86 ratio?
