(2) 383 engines
(2) 383 fresh engines, ready to go.
$5000 with aluminum pbm heads, shaft rockets, aluminum edelbrock intake, roller comp cam, vapours crank, je pistons, high volume oil pump, water pump, pulleys, racing 8 qt oil pan. H-beam rods, 4 bolt main,
$6400 same as above with dart pro-1 aluminum heads,
Both are fresh and ready to go.
Fireball
Sealed and Ready
motors have been garaged, sealed, lubed, and rotated, monthly.
These motors would cost you nearly $10,000 if you had them built.
The last freshening up was $2100.00 each. This was performed by Fast Racing in 2009, and the Vulgamore Machine in 2011.
Ready to go. The only reason that I am selling them is cutting back and I have (4) race ready engines selling these (2).
Will sell the Shortblocks without Heads or intakes. on both for $3500.00 each if interested.
Engines have been balanced, dyno'd, decked, honed, and new rings, bearings etc........by a professional. (not me)
Back to the top. Happy new year.
fireball
For some reason, I can't return private messages.
So email me advanced@bright.net
Fireball
The engines are still available. Here are a few answers to some of the pms.
Both for $10,500.00
The $5000 engine has no laps since freshened.
The $6400 engine has 40 laps sinced freshened. Only ran on gas.
Both produced around 580-600 HP. I have dyno sheets available, cam cards, and torque ranges.
Both have never been over 7400 rpms.
