Results 1 to 4 of 4
    Default Shorter right rear 4 bar
    I,ve been seening cars with bolt in brackets on the lower 4 bar on the right side, I guess my question is what is the shorter bar doing?
    in a van down by the river
    716
    Default RR bar
    I am assuming you are seeing it on a MasterSbilt. They have a different 4 link bracket on the
    Gen X cars. They bolt on a shortner bracket on the bottom bar to make it a 15" bar, which is a standard bar length on there Smack car. If I am remembering correctly.
    Sep 2009
    200
    A shorter RR lower bar will speed up indexing of the birdcage and tighten entry.
    Jun 2007
    1,421
    Standard lengths for a Smack car are 15.5 bottom and 17.5 top. GenX is longer in the brackets welded to the frame.
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
