turnkey dirt late model with tons of spares and rampovers for enclosed trade on mod
here is a 2005 swartz dirt late model just back from shop getting new bumpers and checking out has new decking black new sides purple remote charging posts and batterry shutoff , has brand new never had gas in it 32 gallon jazz fuel cell on slider brackets kirkey 17" intermediate seat with red cover and head support good impact 5 point belts , new shifter and rods hand clutch , wilwood masters and brake pedal full compliment of gauges water temp oil temp fuel pressure and oil pressure 10 grand memory tach , electric right front shutoff, msd 6aln box and blaster 2 coil has wilwood hubs and brake calipers and rotors on all corners afco shocks and springs aluminum radiator md3 nose in good shape bert trans with reverse mount magnesium housing with new starter fast track lightweight steel driveshaft 4 aluminum rims on car with good set of hoosier 1450 tires 1 beadlock 3 nons all 15x14x5 wide engine is a 355 ci sbc only thing needed to finish to get race ready is to drop engine in car add carb and throttle pedal and race also here is a long list of spare parts mainly new parts
1 set of rampovers for enclosed trailer steel frame with wood and diamond plate aluminum runners
2 extra fast track driveshafts
2 trays of sparkplugs new not complete trays but probably 10 or more complete sets
brand new lunati true roller timing chain set for sbc
new in box aluminum timing chain cover and bolts and gaskets sbc
howard stewart sbc stage 3 pump in great shape
2 15x14x5 beadlocks with hoosier tires
1 15x14 weld non lock 1 wheel
4 15x14 steel wheels
7 more tires hoosier and american racers
1 md3 nose in great shape with hood fill
1 md3 nose good for spare with hood fill
2 oil pans 1 brand new 8 quart double kick 1 used in great shape pro cam pan with pick up
1 set of new in box aluminum pulleys upper and lower with new in package set of belts sbc
2 extra threaded body pro shocks 1 dummy and 1 9" with 2 complete new sets of coilover kits
bunch of sbc new gaskets valve covers, oil pan one piece rubber gaskets head gaskets intake gaskets more
extra hood
extra set of brand new headers
fluiddampner 6 1/4 balancer internal balanced type with brand new in package billet pointer
new set of intake bolts in package with wrench sbc
cv products mecanical fuel pump with new in package fuel pump mount roller fuel rod
brand new in package melling high volume oil pump pickup and oil pump rod
new in package sbc oil pump stud
new in package oil filter adapter with new bolts
power steering pump with head mount and lower mount brackets
2 sets of in box brake pads
afco in box 2 balljoints
2 new carb spring kits for throttle return
brand new wix oil filter in box
brand new roller cam thrust bearing and lock plate and bolts
bert complete two piece flywheel and htd and new belt retainer for sbc with 1 piece seal crank
and probably more will trade all on modified race car in as good a shape as mine have tons of pictures i can email of car just got new body and decking from body man today finally will be adding it by weekend and ordered a new flywheel for bert today as soon as it gets here will be bolting engine in car unless sold 757-374-3159 or dirtnut10m@aol.com for more pictures or to send pictures of trade offers thanks frank
forgot to add has new dominator plastic fender tops kicks and sails trick fiberglass roof more might have more parts to will check if it looks like feels like or smells like a dlm part its going
