Results 1 to 2 of 2
    Mar 2008
    121
    Default Ford engine Yates heads top notch piece with all accessories
    This is a AWSOME 404 cui ford mod motor,Ford SVO block 9.5 deck height,billet crank,Olliver rods,Diamond pistons,Comp Cams custom ground camshaft and roller lifters,Jesel shaft rockers,PSI valve springs,Roush/Yates heads and spring oiler valve covers.All of the best parts NO JUNK! also included is a water pump and pulleys,BLP belt drive fuel pump,Kse aluminum powersteering pump with resevoir,Racing alternator,Msd distributor and powerboost wires,your choice of custom built carbs Bolaws alky or Quick fuel E-98 (ethanol)fuel log and all plumbing,Quarter Master mag bellhousing with reverse mounted starter,Quarter master aluminim flywheel,Stock car products rear mounted external oil pump,Howe custom radiator double pass with built in engine oil cooler,also Schoenfeld headers.This engine makes very smooth power and torque,easy to drive,have engine dyno and chassis dyno sheets
    Way to much to list call if interested
    Greg Bates
    217-714-1711 cell
    217-253-2721 shop
    Sold our car and no longer need price $13,200
    Mar 2008
    121
    to the top please
