Results 1 to 2 of 2
Thread: 350 SBC engine
    Oct 2007
    Winfield, IA
    981
    Default 350 SBC engine
    ‎350 SBC. Casting #207 4 bolt main block, std bore, 3.48 gm crank, flat top pistons, GM 5.7 rods, 9:1 compression. Heads are 882's, 1.6/2.02 valves, screw in studs, guide plates. Short block with heads only------> No cam, lifters, timing chain, pushrods, rocker arms, intake, oil pump, oil pan, etc. Engine came out of a 1984 Chevrolet pickup. Was freshened with new rings, bearings. Ran 2 races in an IMCA stock car last season. $1000. Can make it a complete engine for $1400. Will sell without the heads (short block only) for $650.
    JD's Performance
    13034 Hwy 99
    Wapello, IA 52653
    319-931-0677
    Oct 2007
    Winfield, IA
    981
    Sold~~~~~~~~~~
    JD's Performance
    13034 Hwy 99
    Wapello, IA 52653
    319-931-0677
