Difference between driveshaft angle and rearend vertical angle. Doesn't matter what type of rearend it is. For a reference on a QC, you can use the j-bar plate as stated above or the rearenc cover ribs.
Pull bar....A guy told me a couple of years back a way of doing it off of the back cover plate and subtracting the angle from 90 degrees....or something like that????
You do it just like you did on your 9in the other side of the pinion plate. Or like they said you can use the back side of the gear cover because its flat to the pinion. I lay mine across the nuts that actually hold the cover on.
