Results 1 to 7 of 7
    Jan 2012
    georgia
    13
    Default metric car setup
    the rules just came out and they are allowing us to now run racing springs and adjustable cups.what springs should i run and is there anything i can do with my rear trailing arms. should i take off my sway bar or not.car weights 3400lbs got to run street tire i run 245/60 and 255/60 bfgs.any help would be appr.
    Rf 900 lf 1000 rr 200 lr 250 take sway bar off redrill ur top arms for pinion angle 6-8 put ur lowers as close up to the rearend housing as u can
    Demon Chassis
    Jan 2012
    georgia
    13
    well i was goin to buy a set of the adjustable trailing arms for the top and how can i move the bottoms up do i need another bracket or can i re drill. thanks for the help
    Yes u can jus redill
    Demon Chassis
    Jan 2012
    georgia
    13
    thanks for the help and i mis read the rules its 3200 does that change anything
    No u can go softer on both front springs iv went down as low as 750 on the rf at 3400 jus dont let people tell u it wont work it works great
    Demon Chassis
    Jan 2012
    georgia
    13
    do i need to keep the 100 pound split
