**Susp & Misc--NEED GONE**
Suspension Parts:
1 – BSB 5” Coil over Kit, Complete (Used 2 yrs)#6650-B $35.00
1 – BSB 5” Coil over Kit, Complete (Used 1 yr) #6650-B $45.00
Springs:
1 – Afco 16” / 250 lb ( Like New / 1 Night) $20.00
1 – Afco 9-1/2” / 600 lb (Like New) $10.00
1 – Afco 9-1/2” / 600 lb (Used) $5.00
1 – Afco 5” x 6-1/2” Pull Bar 1200 lb (Used) $5.00
Misc Items:
1 – MSD HEI Cap #8411 & Rotor #8410 (Used) $15.00 set
1 – MSD HEI Cap #8411 (Used) $10.00
1 – HEI Remote Coil Conversion (Used) $15.00
1 – HEI Distributor, Complete w/ Steel Gear,
& Remote Coil Conversion (Used / a little loose) $95.00
1 – Bronze Gear for Distributor #SP-547-8471 .500” (Used) $25.00
1 – MSD 6AL Ignition Control (Old Style but like New) $100.00
1 – Aluminum Bell Housing For S/B Chevy. Painted Pink. $75.00
1 - Complete Set – Stock GM Crank, Pistons & connecting rods.
Pulled out of 350 block (never bored), turned free. $90.00 set
1 – 32 gal Rectangle Fuel Cell (Old Style cap) painted white. $75.00
1 – 15”, 6-Blade Plastic Flex Fan (Used) $10.00
1 – 19”, 4 Blade Steel Fan White (Used) $20.00
1 – 15” Padded Steering Wheel w/hex Disconnect (3” dish) $25.00
1 – 605 GM Power Steering Box with rebuild kit (Need Rebuilt) $80.00
1 – All Star Power Steering Pump w/Bracket, Reservoir & Hose (2 Nights) $165.00
For Sale: 1 - Fire System complete with bottle (5 lb) & pressure gauge, two nozzles and line setup, all fittings, control knob w/4' cable & Heavy Duty mounting brackets to frame.
Bottle is marked as previously filled with DuPont FE-36 not Halon! Needs Charged.
$125.00 OBO
Can send pictures!
All Items are located in Beatrice, Ne. (Can get to Lincoln, Ne. If that Helps)
Call or Text Jim @402-239-9282 or Justin @ 402-239-1384
Or E-mail for more info Jim @ jjurgens22@Gmail.com or Justin @ jurgens.j@hotmail.com
Thanks, J & J Racing
