Built 350, carb to oil pan, clutch, tranny bellhousing, Everything goes CHEAP**
I have a Built 350 with 800 proform carb, performance intake, new engine works 525 lift cam, engine works valve springs, new retainers, new keepers, heads been shaved 40 thousanth's off for more compression, new high flow oil pump, new pick up tube and new moroso oil pan, cv starter, cv power steering pump, and alternator, msd box, msd pro billet distribitor new timing chain and seals and cover, moroso valve covers, 3 speed trans, explosion proof bellhousing, quarter master clutch and flywheel also goes, everything goes from carb to oil pan to trans, and clutch, very strong and good running motor, PLENTY of power, only reason for selling it is moving on to something diff, i have way more in this set up, just wanna get it moved to make room in shop, everything is located in North Carolina!!!
$3500 for everything
or trade for enclosed trailer.....
reduced
price reduced to $2500 for all, need to make room in shop, motor runs very good, ran it in my open wheel modified......willing to meet half way for delivery
