Misc parts for sale...
350 block bored .60 over.V1218CNV...010 ...2 bolt...needs cleaned,cam bearings,frost plugs installed.Have crank that goes with it.Crank has had some machinging done cuz there's numbers scribed on it....$75.00
Crower solid lift cam..#00351..intake .525 lift,exhaust .543 lift with lifters....$75.00
8 Speed Pro pistons on stock GM rods. .060 over...L2252AF slightly domed.....$50.00
Holley Alcohol Hardcore 750 carburetor...$100.00
High Volumn oil pump..M55HV...$20.00
Aluminum water pump..like new..short style...$20.00
Afco motor mounts...$10.00
Block mount for power steering pump...$10.00
2 gold aluminum shifter rods with heims...$20.00
16 push rods...7.850 size...$15.00
15" black steering wheel with hex disconnect..$20.00
Aluminum carb plate with Holley 34R-6657B fuel pressure regulater...$30.00
4 weight brackets for round tube...$10.00
20 Lb. lead weight with brackets,round tube...$15.00
11" braided line with #8 ends...one end is 90 degree push lock end...$10.00
19"braided line with #8 ends...$10.00
41" braided line with #8 ends...$15.00
17" bar with 5/8" heims...$10.00
42 " hose with #10 ends...$10.00
1 black window net..$5.00
2 fish net type window nets,1 red,1 black...$5.00 each.
New hand bead breaker...$15.00
RCI Blue racing shoes..worm once..size 11..$20.00
Please text my number or call (309)992-1103
Would make someone a good deal on everything!!!
