Results 1 to 4 of 4
    Oct 2009
    iowa
    54
    Default Rear ride height ??
    right know i have a 10in 225lr spring and a 10in 175rr spring.. with adjustable spring spacers. 3100 pound car all stock mounts and locations .. on the lr i got my spacer all the way down and right up alittle.. what does a taller spring do and if i would put a taller spring in my ride height would be high right or what do i do.. i have no adjustablelty on the lr and if i do it my left side ride height would be higher then right even moving the right adjuster
    Oct 2009
    iowa
    54
    no ones as a opinion
    Sep 2011
    104
    Not sure I really understand what your asking. But here goes. If your wanting some adjustment cut part of the bucket off your adjuster. All 4 of mine have been cut.
    Oct 2009
    iowa
    54
    sorry,, why do ppl run a 13 and bigger springs... and if i ran a 13 in spring over my 10 what would be the pros and cons
    thanks
