412 & 360 SBC longblocks FOR SALE
FOR SALE-
412 SBC complete longblock, (for Street/Strip, Circle Track, Figure 8)
400 SBC bored .060, fully balanced, honed & decked, stock 400 crank, 5.7” reconditioned rods, Hypereutectic flat-top pistons, Moly ring, Comp Cams roller-tip rockers/ hydraulic lifters/pushrods, Comp Cams 270 cam, Airgap intake, Edelbrock 750 CFM carb, Edelbrock chrome valve covers & air cleaner, 3947041 64cc heads (surfaced, NEW bronze guides, NEW valve job, NEW 1.50/1.94 stainless valves, NEW .550 lift springs and NEW hardened retainers & locks. These heads have casting dates of K 7 8 & K 8 8). In car, can hear run. $2000
IMCA Stage 2 Stock Car motor, 360 SBC longblock,
350 4-bolt main block, GM steel crank, Comp cam & roller rockers, LW Mahle pistons & rings, IMCA legal spec EQ heads, Edelbrock alum intake, alum valve covers w/rubber gaskets, Pro Comp EDM lifters, Power Bond harmonic balancer, Clevite rod/main bearings, Eagle 6” rods, 1.50/1.94 valves, machine work (valve job, milled heads, bored/surfaced block, assembled rods & installed cam brgs, balance assy) by Midstate Machine (DM,IA). NO oil pan, oil pump, pickup screen or oil pump shaft (available for add’l $187). Built for IMCA Stock car with 500 CFM carb. Comes with FREE chassis dyno, $4500
Email rldnjspeck@yahoo.com or call 641-499-2190 for more info. Pics available. Garwin, Iowa
