Holley Strip Dominator Intake, SBC Chevy 300-25
The Holley Strip Dominator manifold 300-25 has been designed for use on small block Chevrolet engines (262-400 c.i.d.) The 300-25 is to be used on 1957-86 all models and 1987 & later with aluminum heads. This is designed for competition and off-road use only. It has no provision for EGR and no exhaust heat to the manifold. This can adversely affect idle stability and part throttle operation, if used on a street-driven vehicle.
•Single Plane with Isolated Plenum
•Square Bore Carburetor Mounting Flange
•Isolated Water cross-over
•Power band: 4500-7600 RPM
•Height: Front 5.11", Rear 5.97"
•Port Size: 2.05” height 1.22" width
I have 3 used. They need cleaned but are in good condition, threads are good, no cracks. 2 are slightly ported, 1 is not. $50 EACH.
Email rldnjspeck@yahoo.com or call 641-499-2190. Pictures available. Garwin, Iowa.
