I have for sale a 400CI SBC that I used in my Modified. All parts were new 28 races ago. All machine work performed by Williams Precision Engines. I have well over 10M invested as you can see by the list below. I’m asking $8995. I also have the Holley HP WPE version alcohol carb that you can have for an additional $800. This carb is dyno tuned to this engine. This carb is fully adjustable with jets for the idle and high speed air bleeds. Reason I’m selling is because I’ve sold my car and taking a break from racing. E-mail msmotorsports@nuvox.net, or call 513-284-8966• Dart Little M block 2.650” mains 4.125” bore• Cola Crank 3.750” stroke• Carrillo 6” rods with the SPS CARR bolts 2.100” pins• SRP Domed pistons with Total seal gapless rings• Dart Pro 1 aluminum fully ported cylinder heads. All port work performed by Roger at Williams Precision Engines. • Manley NexTek valve springs with titanium locks and retainers• Crane Gold series aluminum rockers with ARP studs. • Comp Cams 7/16” one piece duel tapered pushrods.• Howards full roller modified circle track camshaft.• ARP main studs, oil pump, and head studs• Edelbrock 2925 Super Victor intake ported to match heads with water hoses to rear.• Adams water pump with cooling lines to side of both heads. • Canton 11-120 7” Circle track oil pan.
