rear lowers
Will swedge and heims mounted in stock location hold up on a metric or will they break? Right now they are mounted straight from the stock frame mount but i would like to move them back to stock location on the rear end...
»»*†HÀ†§ HÓ††™««
»»*†HÀ†§ HÓ††™««
I plan on trying the same thing. Uppers too. My main reason for the uppers is more room to raise the front where it mounts to the chassis.
yeah they work fine, i use 3/4 aluminum hex tube, and 5/8 bolts, only broke one, that was casue some moron looped it into the infield and drove back out on to the track the wrong way and hit me in the front of the lr tire... pretty sure just about anything would have broke
bushracing67
which would hold up better over the other steel tube or hex alum?
»»*†HÀ†§ HÓ††™««
