Pullbar left to right
What does moving the pullbar left to right on the rear end do to the car? Is there really a "sweet" spot to where you can adjust it in too or is it an adjustment people are making nightly? Any help appreciated.
Which tire is closer to it will pull more on that tire, ususually toward the right, loosens car on throttle, toward the left, tighten car on throttle. We never moved it much thou. Good luck.
Hagen14t
I don't think it makes a difference at all on the rear end itself... I know angle, the toe, and height will change how well the pull bar works but moving it on left and right the little bit you can on most rear ends doesn't change anything in my opinion. Just set it directly above the centerline of the pinion and leave it there.
