pierce upper control arm lengths
I have a 07 pierce I bought as a roller, I think it has the wrong upper arms on it. Any help would be greatly appreciated!! It is not a scorpion car, if that makes a diff...
pierce
Yea figured as much, be there saturday, Thanks!
silver6sp7
7.5 in on the right side with metric lowers, 7 in if pinto , on the left side, 10.5 if metric ,10 if pinto
scorp is another animal .
how to you measure upper control arm? do you measure to back of the the cross arm or in front of it ? I know you measure to the middlee of ball joint. just not sure what to measure off the cross arm mounted to frame.
I believe center of arm from center of shaft to center of ball joint.....
