Results 1 to 6 of 6
    Jul 2007
    18
    Default Lots of Ford 2300 Esslinger parts SVO head, (2) goldstar setups, crower roller cams
    (6) good 2.3 blocks. $50 ea
    (1) block race ready bored .30 over SOLD
    (4) cranks $25 ea
    (2) front pans with baffles and tray $125ea
    *SOLD* Esslinger Race rear sump pan with crank scraper with pickup tube $200
    http://www.esslingeracing.com/mercha...gory_Code=OLPN
    (1) 2.0 block/head with rear sump pan $100
    A few transmissions $100 ea
    Esslinger SVO Alum head 12.5 compression (head needs re-assembled)
    Esslinger Port matched intake w/Holley 500 (Earl Parker Carburation Stage III)
    Esslinger 1 steel billet cam .620 lift w/cam card
    Esslinger 1 steel billet ARCA cam .658 lift w/cam card
    New valve springs, roller rockers, valves, titanium retainers.
    $2000 shipped for the head and your choice of cam with the port matched intake w/o carb.
    2 sets of ARP head studs. $50 ea set
    1 set of ARP main stud. $50
    1 set of Chromoly main studs $40
    Lots of new pistons rings, rod and main bearing 2.3 and some 2.0 ALL namebrand ACL/Clevite $150 for the lot.
    New crower 5.7 rods and like new 5.7 wiseco .30 over pistons $300
    1 set of like new manley 5.7 rods. $185
    2 .40 over wiesco pistons for 5.7 rods. $40 shipped
    (2) Complete Goldstar 7# flywheel/clutch assembly’s race ready 23spline $450 shipped
    http://www.esslingeracing.com/mercha...egory_Code=FLY
    (1) Billet Esslinger Auxillury Shafts w/ changeable gears $150
    Probably more just have not got everything out. These are the big ticket items. I want to sell everything together. I have all of Mission machines build sheets for reference that will go with it too. From San Antonio, Tx
    SOLD -- I also have a Esslinger destroker knife edge crank 2.3 to 2.0 that was $1700 new that I will sell separate for $350. Stroke is 2.750 and must be used in a pre-89 large journal block. STD or .010 main and rods I cannot remember. With .030 over pistons the final cc will be 2057.
    9" rear end pumpkins / gears and all the 8" rear end pumpkins with 5 different gear ratios.
    Would like to sell everything at once but the aluminum head will be the last to go.
    We ran the best parts available!
    Also have a pinto less motor that ran 16.7 in Kyle, TX asphalt.
    PM (prefer pm) I am school teacher and do not have alot of free time or call with any questions on parts and price. I will take pics of the requested items.
    PAYPAL ADD 4%.
    Thanks
    Bryce
    210-827-4430
    Located in Devine, Tx 78016
    Jul 2007
    18
    Bump now with prices. Thanks
    Jul 2007
    18
    Some new prices on the goldstar setups and SVO alum head.
    Oct 2008
    168
    give me a call on goldstar 5306240254
    Dec 2010
    302
    Default goldstar clutches
    doyou still have how much for one? call 678 878 9785 thanks dan
    Jul 2007
    18
    Cool
    Just SOLD everything but 1 roller cam.
    Esslinger 1 steel billet ARCA cam .658 lift 5000-8800rpm range 108 centerline. $250 shipped.
