Results 1 to 9 of 9
Thread: Tire temps
    Jan 2012
    18
    Default Tire temps
    Does anyone measure their tire temps? and How should they compare to one another?
    Jan 2012
    18
    Either nobody knows or everybody knows either way nobodys sayin!
    150
    Default tire temps
    I setup & fine tuned three different cars going by tire
    temps. each one was a fast car,all three are dirt cars.
    dirt2
    150
    Quote Originally Posted by 53003jason View Post
    Check your PM.
    dirt2
    It means you are probably lose. Your driving off the rr. The lr isn't doing much. Kind of like 3 wheeling but with the read end instead. What springs do you have on the rear?
    Jan 2012
    18
    I could be a tight-loose condition heating up the RR tire (which what I was fighting) I would recommend having take temps right when you come off the track.
    150
    Default tire temps
    From what you are saying the car is off on the springs
    or the wheel weights. Could be a little of both.
    I would say it goes in tight then after the center it comes
    off the corner tailed out.
    dirt2
    150
    Go back up to post # 4an reread it.
    dirt2
    Feb 2008
    Barrington il.
    881
    Tire pro is about 75 bucks! Buy it and learn!!!!!
