Results 1 to 11 of 11
    Medford, OR./Tulare, CA
    1,063
    Default Need some stuff.
    I am in need of a 2.3 adjustable cam gear, tensioner and double groove power pulley. square tooth or round. but if round, I need the lower crank gear and aux gear. Can be stock gears on aux and crank if round. Prefer used stuff. Doing this engine on a budget for a friend. Have three nice efi intakes for a 2.3 ford. willing to trade out. zip code 93274. dannyracer6@yahoo.com. Also looking for a good used 8 gal fuel cell with can. Thanks.
    dr6 motorsports
    430
    got a esslinger square upper cam gear--$40 plus shipping
    1,063
    Is it in good shape? Reason i ask is that some times they start to strip out on the three adj bolts.. I would be interested. Get back to me asap. Race season is just around the corner.
    Dan
    dr6 motorsports
    Illinois
    1,690
    Quote Originally Posted by dannyracer6 View Post
    danny, I have an old racer walsh adj. cam gear Ill never use (sq. tooth). It has an aluminum center section, but one of the slots is broke off on the outer edge, BUT it will still hold tight. I also have a double groove esslinger power pulley & a 5" OEM water pump pulley that line up perfectly together, I have a good belt for this setup also. AND I have many OEM cam/aux gears. Ill box it all up & ship for $110. For a tensioner, I got a brand new one from autozone from a '98 ranger 2.5L, bolts right on a 2.3L head, cost $30 and its a ball bearing unit. Way better than the 2.3L OEM tensioner. Let me know if interested, I can text pics to a cell.
    430
    here is a picture of it-nice shape
    1,063
    Quote Originally Posted by Dirtman29 View Post
    can you send picts, to 559 802 7006, thanks. Dan
    dr6 motorsports
    Illinois
    1,690
    I will send pics now...
    Dec 2010
    302
    i have fuel cell and degree wheel if you still need! call 678 878 9785
    Feb 2009
    300
    I have 2 brand new square tooth adjustable cam gears. $25 each plus shipping.
  10. #10
    1,063
    Corkey, check your PM.
    dr6 motorsports
  11. #11
    1,063
    dr6 motorsports
