Were is a good place to get regulator and a tank for nitrogen
If you have an airgas in your area tell them you want a nitrogen regulator. Ours was around $70.00. Advantage is its high psi rating so if your running gas shocks you can have plenty of pressure to put in your shocks. A converted oxygen regulator will just go up to 120 psi or so. Some gas shocks require 190 to 200 lbs psi.
