Results 1 to 3 of 3
    Mar 2012
    2
    Default harris set up help
    just bought 2001 harris mod to be run as b mod. has chevelle frt clip and rear under slung set up as 3 link,rear springs on eliminators mounted on 19 swing arms . any set up help would be great as far as frt and rear spring rates and ride height measurements. thanks for any input
    1,353
    If you haven't already, give Harris a call and see if they can give you a starting point. Just a suggestion.
    Default setup sheets
    check your P.M's
