parabolic leaf springs tech adding a leaf?
can the short bottom leaf from a multi leaf be added to a parabolic leaf to increase the rate a little bit to make it a higher rate on right rear,if so should the long part of the leaf be placed toward the front or rear of the car?to tight on entry with a 225 on left rear and 200 on rr 3100lb camaro,car is perfect thru past middle and out,tried more compression rr shock,less rf spring rate,less cross,i am convinced it needs rr spring siffened a litlle by adding a leaf if it will work,has anybody ever tried it.
Reason: more info
yes you can...go with longest leaf tho'
