Results 1 to 11 of 11
    May 2011
    167
    Default Cutting in the middle
    Okay lets say that the line during a feature is you have to go into the corner in the middle and get the car to turn enough to come out of the corner right on the bottom. What the best way to cure a slight push in the middle. Its not even a push, just need the car to rotate just a little bit better. What would be the right area of the car to look at?
    maybe try to lengthen rt side bars by 2 rounds
    in a van down by the river
    1,893
    Default cut
    LR bottom bar up one hole. Should put a hint of steer in it, and a bit of traction.
    All replies will be different, so you will probably have several options from alot of people.
    Jan 2012
    111
    Rotate before or after you are on the gas?
    May 2011
    167
    Just before i get back to the gas.
    Jul 2007
    558
    softer LF spring.....raise lower right bar.....little more stagger
    Chris Zogg
    Jan 2012
    111
    Enough back brake should be able to rotate a mod any time before you get on the gas.
    Brake pad choice and caliper size on each corner are important for corner speed.
    Mar 2009
    Dogwood Illinois
    701
    Soften LF or stiffen RF (adds wedge) or just add wedge, or less rear % or add left %, add some trail (static steer)or (bar angles dynamic steer).
    Sounds like a classic case of needing more stagger in the rear.
  10. #10
    May 2011
    167
    Thanks for the help guys.
  11. #11
    Oct 2008
    154
    all of these suggestions are good , one other that was not mentioned but I like is pulling the Left rear tire under the car a little more. If your using a 2 in. offset wheel go to a 3 in. offset. Or whatever your using go to a deeper offset.
    Thanks Kevin
