Usually run biscuit pull bar but trying a spring pull bar during the heavy track conditions. Lets see if I got this preload down to what its doing. If its a 1200 # spring, that means it will take it 1200# to collapse it one inch? So if your preload it a 1/4 inch, what are you doing exactly. Seems as you compress spring more, the more pressure it would take to initially start it compress? Is this close or if someone has an article on this. Thanks for the help.
