oil
You would be able to see it. It looks like a newborn baby crapped in the oil pan. Milky cream in color, kinda thick.
Running a 180 Thermostat will help in the warmup process, and have the motor to a good operating temp for a better fuel burn.
180-200 degrees is optimum water temp range to run alky.
If u are running cooler you are going to contaminate oil with alky, and have to change it more often.
