Results 1 to 9 of 9
Thread: Dot air psi
    Default Dot air psi
    1 st time on dirt with a dot 3200# pures stock with 235/70r 15 have no idea what psi to run any help appreciated
    May 2010
    632
    I ran 18 left and 20 right and some ran 20 -25.
    Jan 2011
    217
    it depends on the style/condition of the track. I run 18-34 on the left, and 29-34 on the right.
    Some of the numbers guys post on here I wouldnt even think of running but it must work for them. On a fast, high banked track I have knocked the RR tire off the bead at 27lbs with aero wheels and a TUBE! Eric
    May 2010
    632
    Eldora in ohio with a 3400 lb car, 18 and 20 with no tubes, no problems for 7 years.. I tried the higher pressures and car was always to loose. Try something and let us know.
    Sep 2011
    104
    15 rf 14 rr and I think I got the lf down to 8 one night. This was 275/60/15 on a 8in wheel. Ya had to vet used to it. When ya entered the corner you could feel the tire roll over.
    288
    20-24 right side, 16-20 on lr and LF I always ran it around 12-16. Would go up from that if track was heavy and lower when track was really dry. No tubes. Radials need more air than racing tires
    Aug 2010
    122
    you only run high tire pressure when and tubes when you dont run beadlocks, and thats not safe, ive never not ran beadlocks on the right side, but i run 14 right side, and 17 left side
    Jan 2011
    217
    Most classes that require DOT tires, DONT allow beadlocks. If you can run beadlocks then you clearly can drop the pressure a lot on the right side. Eric
    Mar 2008
    766
    about 16 on the rr is as low as I could get down to and be consistent I ran 20 rf 18 lf 17 lr 16 rr this on a dry slick on a heavy track I went up a couple of 3s only because of rr We couldn't run Beadlocks either We did glue them on Mon to run Sat But honestly I don't know if it was worth the trouble
    my daughter my sailor my hero the next greatest generation is our men and women now in harms way Pray for them
