Fresh 383
Fresh 383 29 total nights about 1,000 laps GM block with Pro Gram engineering billit caps, Callies crank, Eagle 3d H beam rods, Ross pistons, tool steel pins, Comp Roller valve train, Hollow stem Dell West valves, Steel RHS heads 48cc Chambers 220 runners and matched intake, ACL Coated Bearings, Total Seal TS1 gapless rings, Cometic MLS head gaskets, Plumbed from water pump to center two exhaust ports for extra cooling, Intake also plumbed front to rear. All parts were checked when freshened and professionally assembled. Right now set up for external oil pump with champ pan, if needed will change out for a new pan and internal oil pump. This motor was built specifically for bull rings and tight 3/8 race tracks. Very smooth and reliable HP. Ready to go for $ 6,000.
EFR Motorsports llc
Team EERC Dirt Modifieds
(573)-330-8462
