Results 1 to 3 of 3
    Apr 2009
    Arizona
    601
    Default World products ported steel heads,hvh 390 intake,t&d shaft rockers
    I have a very nice set of world products ported steel sbc 64 cc bare heads, a matched hvh intake that has been ported & has a removable 390 insert in it & a set of t&d shaft rockers that fit these heads,not sure of the ratios as the numbers have been ground off. If interested call 520 358 2022.
    Apr 2009
    Arizona
    601
    Default World heads T&d shaft rockers,Brodix intake.
    These heads are ported with the push rod guides moved over & set up for shaft rockers. The heads are bare & nice. I have a full set of 2.1 ratio T&D Shaft rockers with stands & shims that go with them & a match ported Brodix HVH intake Manifold that you can put different inserts in on the top. This setup originally cost over 4k. Make me a reasonable offer for all. 520 358 2022.
    Apr 2009
    Arizona
    601
    Default Heads intake & rockers
    The shaft rockers alone cost what im asking. I will take $1,200 for everything. 520 358 2022.
