Results 1 to 1 of 1
    Aug 2009
    11
    Default 2007 Rayburn 104 With 4 race old 604
    PARTING OUT OR SELL THE HOLE GROUP. I CAN MAKE SOMEONE A GREAT DEAL IF YOU WANT THE ENTIER LIST
    2007 Rayburn 104 under rail chassis
    >The chassis has had a front clip installed about 6 races ago by Bill West Enterprise
    >Chassis with deck, (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit, Gauges, master cylinders, peddles, steering shaft and fuel cell. $1800.
    These parts only have 4 races on them!
    604 with original seal bolts. As it came from gm $4400.00. Approx 150 laps. Never turned very hard.
    >krc serpentine belt kit with adjuster $200
    >krc power steering pump with res. $175
    >Stewart high volume water pump $50
    >Shoenfield headers (latest and greatest with 12 inch extensions) $200
    >Willeys E85 carb with spacer $800
    >MSD distributer $150
    >scott plug wires $100
    >fuel log $40
    >fuel pump carter high volume $75
    >MSD Digital 6AL ignition control $150
    >single pass radiator $100 New
    >17" flex a lite fan $20
    >starter $125
    >Bert 2nd gen trans with shifter $1500
    >8" trans yoke $50
    These parts are a little older but in very ggod shape. We raced it last weekend!
    >36" aluminum Colman drive shaft with u joints $125
    >37 aluminum Colman drive shaft with u joints $125
    >winters quick change $1250
    >Rayburn aluminum swing arm bird cages $80
    >Rayburn swing arms $25 each
    > wildwood 5 wide rear hubs with bearing $50 each
    > wildwood 5 wide front hubs with bearing $50 each
    >4 brake rotors $25 each
    >4 brake calipers $50 each
    > 5 Koni shocks with coil over kits $50 each (2) 7" (2) 8" (1) 9"
    >quick change gear sets $40 each Set 10 (6.57) Set 24 (7.04)
    >front purple spindles $35 each
    >2 uppers with ball joints $90 each
    >2 lowers with ball joints $90 each
    > 8 springs $30 each 10" in (2) 500, 550, 450 12" (2) 400 14" 300, 350
    > sweet rack $600
    Can mix and match tires as needed. Have lm40 and lm20.
    >4 bead locks with covers and tires $175 each
    >4 cover non lock with cover and tire $125 each
    >2 standard rim $90 each
    All prices are negotiable. Thanks for looking
    Call or Text 217-979-7140
    AMT256@yahoo.com
Tags for this Thread
Copyright © 2021 vBulletin Solutions, Inc. All rights reserved.
