i just went through this and i hame metric spindles here from a monte carlo/cuttlass etc. and tried putting them on a s10 and they are NOT the same they will bolt on and hook all up but the shaft that the rotor slides on is longer on a s10 and the outer bearing has a larger ID.I didn't try using the metric spindle with a metric rotor to make sure the caliper sits correctyly but it might
