Results 1 to 3 of 3
Thread: LR Spring
    Default LR Spring
    Has anyone gone down to a 150 spring and had success? what will it do to the car? were currently running a 175 in the LR
    Batavia, OH
    13,641
    What type of car are we talking about? Setup? I used to use a 150# spring a lot with a lr clamped setup. A common lr stacked spring deal comes out to a 133# rate.
    Atomic - 2
    Nov 2009
    Glennville, GA
    745
    Lowest I have gone is 200 (currently using), I haven't gone softer. I was afraid of bowing the spring.
    Crew Chief "Tip of the day":
