e-85
have 604 new stealh carb e-85 will not take off. any help thanks
check content of fuel----86 is the max and and 83 would be the min
are you power braking?
what is your water temp?---they have to be warm--(200 range)
timing 34 degrees and locked
back the mixture screws out to 1 1/2 from seat ---readjust base idle----will seem lopey but has had good results
other than that----give us a call
Brad
330-540-7223
www.race-1.com
Reason: added info
