Results 1 to 6 of 6
    Default we need some f*$%in Help.
    We have a 09 warrior with a 604 crate motor and was thinking of trying the bump stop in the 5th coil, any suggestions on does and donts with this. Any suggestions would be appreciated,. Thanks have a blessed day.
    Port St. Lucie, FL/Sardinia, OH
    7,718
    My first suggestion would be don't try it. If you are dead set, I would try a 150# spring, 3/8" preload and a relatively soft bump with 1.5" shock shaft before bump contact.
    Atomic - 4
    Florence - 1
    Moler - 1
    I77 - 1
    Florence - 1
    Eldora - 1
    we are just trying to get faster we have did bump on right front like it for dry track now doing stack with little rougher track and was going to do somthing with the 5 th coil just trying to get every bit we can get
    Jun 2007
    2,781
    Unless I was already lapping the field, there are about a hundred other places I'd look for speed.
    Mar 2008
    Rock Hill
    85
    Matt49 hit the nail on the head!
    Jul 2009
    154
    i agree with everything said so far,.....
