Results 1 to 2 of 2
    Jun 2008
    169
    Default HELP 2300 solid lift jam nuts backing off.
    Ok started running the solid lift head. Just changed the cam in it and put mouse traps. Ran it 2 laps in hotlaps and about 6 of the lifters backed all the way off. ... Ok so I thought I may have not snugged them good. So we set them again and I made SURE they were very tight. And 3 laps later same thing. I never had the problem with this head until now with a diferent cam and mousetraps.
    1,672
    If valvetrain geometry is correct, you should remove mousetrap and clip and torque to 60 ft/lbs and double check lash. might take a few times adjusting to get them right. If they come lose then you almost certainly have valvespring/geometry issues.
    BUCKLE UP NOW, YA HEAR?
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
