Results 1 to 6 of 6
    Jul 2010
    11
    Default rubber gasket on 9 in center
    Anyone else have trouble with nuts coming loose using a rubber gasket on the center section?
    Jan 2011
    106
    Simple solution...Nylon locks nuts. I use them on almost everything on the car. Saves a lot of time and is much safer. Eric
    Ive always used left over rocker arm nuts. Never had one loose since i started racing.
    Nov 2008
    319
    I have never used a gasket personally, I just use small string, a little bigger then kite string but not too big, start at one stud wrap it one time, then the next so on and so on. Then use nylon lock nuts, never had a leak or a loose center and its dirt cheap.
    Jul 2010
    11
    I like the string idea.!
    dont like the rubber gasket had same problem.. I use RTV
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
