2004 M&M Sportmod
I am in the process of putting a new to me M&M chassis together as a Norther Sportmod. I am looking for some general springs, shocks, and percentages to run to get me in the ballpark. The car is a Ford Crown Victoria stub with the Crown Vic spindles and 2 link rear with 16" trailing arms. It's going to have a 357 Ford Windsor built to Sportmod specs with 360 HP. The main track I will run at is a very wide high banked 3/8. The track usually gets fairly dry slick come our feature time with the top and bottom being fast on most nights.
The car currently is setup with a swingarm Z-link rear with these springs and shocks in it.
LF 750 lbs. WB 75 RF 800 lbs. WB77
LR 350 lbs. WB 53 RR 250 lbs. WB53
If any more information is needed let me know, I'll find out.
I'd appreciate any help guys.
Thanks,
Ryan
set up
Give Mike a call at Mach 1, 309-796-4610
